Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Move 3D PCB Component to intersect with sketch
2 REPLIES 2
alanhartquist
213 Views, 2 Replies
I got a 3D model of an enclosure with a drill hole layout on the top of it. I would like to align a potentiometer to the hole, and update the PCB location, since the pot will be soldered directly to the board.
I can't seem to use the MOVE 3D PCB COMPONENT point to point command to align the pot with the hole layout sketch. Does anyone know the best strategy for this?
I can do a free move, and manually align it, but it will only be so accurate.
Best,
Alan
Labels (3)
2 REPLIES 2
yqliu
in reply to: alanhartquist
@alanhartquist , please have a look at the video below and see if it helps:
The image is not rendering well on web because I compressed it to get smaller size. Please download it if you can not see the steps clearly.
Thank you, I was able to get it to work.
Best,
Alan
