Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Move 3D PCB Component Bug?
2 REPLIES 2
markusYG3LC
81 Views, 2 Replies
Hi
Today I noticed a strange behavior when moving components in a 3D PCB Document. Whenever I selected a specific component in the "Move 3D PCB Component" command, the component was immediately flipped by 90° and precise positioning with the move type "point to point" was not possible.
After spending a few hours with troubleshooting, I found out that the 3D component body always flips back to the orientation it was initially placed in the library package. If it gets moved or a joint is inserted after it is added to the package and the initial move command is closed, the "Move 3D PCB Component" shows the explained behavior.
Bug or feature?
BR, Markus
2 REPLIES 2
jorge_garcia2
in reply to: markusYG3LC
Hello @markusYG3LC ,
This is interesting, I have a feeling that the fact that a joint is in play may have a role here.
@yqliu Any ideas here, I have a feeling that something here is by design but I'm not 100% sure.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
markusYG3LC
in reply to: jorge_garcia2
Hi @jorge_garcia2
Thanks for your answer. I found a workaround that works for now. Let me know if you need a screencast.
Best regards
Markus
