Happy new year Helen
Thank you again for your always invaluable and precious help, and thank you for confirming that this has changed, I still thought I was going crazy! If it is a request from users I understand and I see that you listen to users and thank you.
I see that there are many developments and so much the better, but not the one I amended to fully use Fusion for large projects.
In future evolutions, when will it be possible to import logos or images in a simple way without going through this very old and totally obsolete BMP? When is it possible to draw shapes in a simple way on the grid without using the calculator? A little like ILLUSTRATION or you enter the dimensions you want without worrying about the grid, when will we be able to move a shape, a component via the left and right arrows, top and bottom of the keyboard? In short, a little flexibility in the graphic editing layer would be welcome, but I can only congratulate the evolutions, but it is not what I expected, allowing the choice of font (Custom) is a very good idea, but I would have preferred as a priority the simple import of image in a diagram, such as a transistor PIN out or other component as is done in Electronic Engineering, to do this, I am obliged to make a montage with Illustrator.
Thank you Helen once again for your valuable help and availability.
