Hello. I've just had a board fail in manufacturing because Fusion 360 Electronics didn't spot two vias which overlapped a pad at a different potential. I attach a screenshot. The highlighted vias are on the 3.3V net and are overlapping with a large thermal pad on a device, which is also connected to the 0V net via several other vias. Why didn't the DRC highlight these? I've re-run the DRC to be sure and it definitely doesn't comment on them.
Link copied
