Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Missed DRC violation
2 REPLIES 2
r.cowburn
157 Views, 2 Replies
Hello.  I've just had a board fail in manufacturing because Fusion 360 Electronics didn't spot two vias which overlapped a pad at a different potential.  I attach a screenshot. The highlighted vias are on the 3.3V net and are overlapping with a large thermal pad on a device, which is also connected to the 0V net via several other vias.  Why didn't the DRC highlight these?  I've re-run the DRC to be sure and it definitely doesn't comment on them.
2 REPLIES 2
Hi r.cowburn,
From looking at the snapshot you have posted I am not able to figure out what the issue might be and why the DRC doesn't flag these violating vias. May I ask if you can send me your design stripped of any IP that still shows this issue and I will have a look. What Fusion build are you using? My email address is: constantin.popescu@autodesk.com
Kind Regards,
Constantin Popescu
Principal Software Engineer
r.cowburn
in reply to: r.cowburn
Thanks for getting back to me.  False alarm - it seems that we had accidentally 'approved' the DRC violation.  Once it's disapproved, it shows up as overlapping.
