Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hello everyone,
When I create a milling hole in the PCB design, It does not go through the copper layer in 3D view. How can I get it to go all the way through?
Attached are the pictures where you can see in the 3D model the copper layer has not been cut.
*Please note this is an example sketch*
Hi, @osamaolabi
Did you drilled hole from 3D PCB and then just push to 2D for one time? 3D PCB is relied on 2D now so a round of 3D<>2D sync is needed.
I guess the milling hole is overlap with polygon, right? If my thought is wrong, Would you please share the 2D PCB you demonstrated to us?
Yiqiu
