Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Mergin Eagle with fusion 360. How to add models to the design
3 REPLIES 3
kris.chlapek
134 Views, 3 Replies
Hi Guys
So I synced my Eagle design with Fusion. Is there a way to add 3d models to Fusion?
I was unable to add those models at Eagle level as the webgl seems to be blocked on my company computer.
Only models added by default where transferred like the caps everything else doesn`t.
Also, I had those models with my original fusion design but the push to fusion replaced them with just a block.
If I then push that board from the picture to 2D, the whole thing goes bananas 🙂
3 REPLIES 3
Hi @kris.chlapek ,
I hope you're doing well. Models always have to be added in a library. You can bring your managed library into Fusion 360 and then add it there.
It's possible you could fix the WebGL issue in EAGLE, what issue are you seeing?
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
My Company is blocking webgl as it`s an ad on which may be an security issue. The looking into this now.
Any chance you could screencast how to export fusion library and merge that with eagle?
Or at least show me how to update the model on the pcb3d in fusion 360?
Hi @kris.chlapek ,
I hope you're doing well. Check out this video
https://www.youtube.com/watch?v=VlnHfN2xznk&t=1s
This video should show you how to deal with 3D models in Fusion 360
Jorge Garcia
Join this live stream to learn how to build your own electronic components using the Fusion 360. Put together your symbol & footprints, then complete the process by mapping your 3D model. ►SUBSCRIBE: https://autode.sk/2UvfzRh ►COMPARE: https://autode.sk/2HsSICc ►TRIAL: https://autode.sk/2CA9NqC
