Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
May I ask that shortcut key for change between layers
1 REPLY 1
sellyette
82 Views, 1 Reply
Hi.
I searched the shortcut key for change layers.
But I don't know.😟
Please let me know.
1 REPLY 1
jorge_garcia2
in reply to: sellyette
Hello @sellyette,
I hope you're doing well. There isn't a default a shortcut for this but you can setup your own shortcut using the shortcut command on the top right.
You can create shortcut for DISPLAY NONE 1 for example this will turn off all the layers and then leave layer 1 on by itself.
The display command is the key here.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
