Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
LT6003 CAD Model
1 REPLY 1
vedantpGPYTW
82 Views, 1 Reply
LT6003 CAD Model
I got the CAD model for LT6003 from analog devices. However, I am really confused how I can import this into Fusion 360 to make a schematic with this part. This part was not included in the built in library. This is my first time using Fusion, so appreciate the help.
1 REPLY 1
Hi @vedantpGPYTW ,
I hope you're having a good day. Samacsys Library Loader has not been updated to work with Fusion 360. It currently only works with EAGLE. One option would be to use it with EAGLE and then take that library and upload it to Fusion 360.
I think long-term you are better off just making the library in Fusion 360. It will take a little more work to make the part yourself but I think it will do you a lot more good in the long run.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
