Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
library part naming conventions
4 REPLIES 4
wwfeldman
570 Views, 4 Replies
what are the conventions regarding the naming of standard parts, like resistors and capacitors in the rcl library?
for example, what do the numbers represent in C-US025-025X050?
clearly C is for capacitor, US is for the schematic symbol used in the US.
what do the numbers represent, what units are they in, and where is the decimal point?
likewise for the surface mount parts, C-USC0402 and C-USC0402K
and for the polarized (electrolytics)?
as for the resistors, R-US_0207/2V, R-US_0207/5V, R-US_0207/7
the V means it sits vertically, but i don't get the rest
the description tells me nothing - what does type 0207, grid 5 mm mean?
4 REPLIES 4
RichardHammerl
in reply to: wwfeldman
Hi @wwfeldman
thank you for participating in the forum and your great question.
Let me try to give you some information on this.
For resistors the units are in mm.
      0207/7     -   body diameter about 2mm, length about 7mm. Pitch of about 7mm (actually 7.62mm)
      0207/5V   -   body diameter about 2mm, length about 7mm. Pitch of about 5mm (actually 5.08mm). Vertically mounted
These package namings are standardized in IPC-SM-782.
This table is taken from the following web site with more information :
https://resources.ultralibrarian.com/2020/06/02/0402-package-footprint-resistor-sizes-and-parameters...
C025-025x050    -  pitch about 2.5mm (0.254mm), body 2.5mm x 5.0mm
C150-054x183    -   pitch about 15mm  (15.24mm),  body 5.4mm x 18.3mm
These values do not give information about the height of a component.
Hope this helps.
Richard Hammerl
wwfeldman
in reply to: RichardHammerl
its certainly a start
which template in "create new package" would i use to make a through hole capacitor,
like a C-US025-025x050?
jorge_garcia2
Hi @wwfeldman ,
I hope you're doing well. I would use the axial or radial templates, these are the closes to through hole caps and what we typically use to generate them.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
wwfeldman
in reply to: jorge_garcia2
does that mean you use a cylindrical model for a rectangular capacitor, such as those in the attached pdf?
