Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Library Footprint with Holes
2 REPLIES 2
RCBakerBorn
61 Views, 2 Replies
Good morning.
I want to know if I create a footprint that includes a holes layer, will those holes transfer over to the PCB layout?
Or are they just outlines?
Will I need to create the same holes on the PCB layer?
Thank you.
2 REPLIES 2
Hello @RCBakerBorn ,
you can place holes in the footprint in your library:
  • here is one example
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
RCBakerBorn
in reply to: RCBakerBorn
Thank you for he reply. I was able to find the hole icon and create them.
I thought by placing an outline on the holes layer it would create the hole.
That was not the case.
I needed to use the hole icon and create a hole and not worry about the layer.
