Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Latest Fusion Update Breaks PCB Layout
3 REPLIES 3
sam.spencer5991
145 Views, 3 Replies
So, just got the auto-update error and downloaded the latest version as described in the fix. After opening it, a few things are now broken. So frustrating, and it seems like this is becoming less and less of a professional tool for doing actual work, and more of a marketing gimmick. When zooming out of a PCB, most vias now have this large white line through them until you zoom in far enough.
Also, some component pads don't want to connect to poly pours (notably ground pours). Really frustrating because without manually routing out every ground connection, I can't complete this layout. I've tried closing/opening Fusion, re-creating the poly. It's strange because some other components with ground pads connect to the pour just fine.
3 REPLIES 3
Hi @sam.spencer5991 ,
I hope you're doing well. This is really weird... couple of things to check. Turn on all of your layers and see if you don't have any items on the restrict layers that may be interfering with polygon connection.
If you are willing to share the files I would be happy to review them to see if there's anything that sticks out.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Hi Jorge,
Thanks for getting back to me. Sure, I'd like to get this resolved quickly. How can I share the design files with you?
I hope you're doing well. Just send me an email with the files directly it's my first name dot my last name at autodesk.com.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
