Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Keyboard Shortcuts
4 REPLIES 4
aeies
1016 Views, 4 Replies
Keyboard Shortcuts
I saw in the July update for Fusion 360 that a new keyboard shortcut feature has arrived. Is it still not possible to rebind the default keyboard shortcuts? For example, the RIPUP command defaults to U, but I would like to change it to what I use in Eagle. I can't seem to find a way to do this? When trying to change I just get the attached error.
4 REPLIES 4
Hi @aeies ,
Thank you very much for your feedback and sorry for any inconvenience.
For ripup trace, via or polygon, the default shortcut is U. This is a special case I need to feedback to team to have a look because that command is not in the drop down list of Ripup in toolbar, then no way to edit that shortcut in UI. Currently sorry that only able to use shortcut U for ripup.
For your reference, for normal command in toolbar, we could click the 3 dot icon to change shortcut if it has defined a default value. Hope it helps a little.
We will keep you be posted if we have any update about this. Thank you.
Best regards,
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
aeies
in reply to: aeies
Hi Helen,
Thank you for your quick reply. I think I understand. It seems like the simple Ripup command is missing from the dropdown menu? It should be like the Manual Route command, where the command has a toolbar option and a dropdown menu option?
Hi @aeies ,
Personally from me, the answer is yes.
The Ripup all in the drop down list as well as other commands in the drop down list of Ripup could trigger the Ripup command panel. But no command for Ripup trace, via or polygon in the dropdown list. Only able to access it from toolbar directly.
We will keep you be posted once we have any update about this.
Thank you!
Best regards,
Helen
Helen Chen
Hi @aeies ,
Hope all is well.
In Fusion Nov release version 2.0.15023+, good news would like to share with you that now we have renamed ripup to Unroute and you are able to change the default shortcut key for Unroute from U key to other key you used in EAGLE.
Please click the 3 dots icon and select Change Keyboard Shortcut to edit the default U key.
Hope it helps.
Thank you very much for reporting this issue to us and hope you have a great day.
Best regards,
Helen
Helen Chen
