- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
i need a zone across a hole only on the bottom side of the PCB where no traces or copper is placed.
I added a polygon on the layer "40 bKeepout" as you can see here:
But as you can see the blue trace is going through this zone only following the standard distance from the hole. Also DRC is not showing any warning concerning this. As you can see I also placed a circle as a keepout which is also not recognised.
Is there an other way to place keepout zones ? Do i have also to place a polygon on the restricted layer ?
Thank you
Torsten
