Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Kann ein EAGLE Projekt in Fusion 360 geöffnet / importiert werden?
4 REPLIES 4
Florian__
333 Views, 4 Replies
Beim Abo von Fusion 360 ist ein EAGLE Abo dabei. Kann dann auch ein bereits verhandenes EAGLE Projekt in Fusion 360 geöffnet werden bzw. wird diese Funktion bald kommen? Oder kann man praktisch den Electronic Design Editor als seperates Programm ansehen?
4 REPLIES 4
edwin.robledo
in reply to: Florian__
Hi florian.piper,
Thank you for participating on the Fusion 360 forum. Fusion 360 does support EAGLE design files. In Fusion 360 you would create a brand new electronic document then load a schematic and link the PCB. There is a short video explaining how this works.
I hope this helps.
Best REgards,
Ed
Edwin Robledo
Tech Marketing Manager
Florian__
in reply to: edwin.robledo
Thank Your. Does that mean that the files in Fusion are copies or do the local files also change with changes in eagle?
RichardHammerl
Hi Florian,
the files used in Fusion 360 Electronics are copies from your local EAGLE files. The files you used with EAGLE woll remain untouched.
Richard Hammerl
Florian__
in reply to: RichardHammerl
Allright. Thank You!
