Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Is there a way to export .edb files with correct (blind via) padstacks?
1 REPLY 1
mweigand82BMM
99 Views, 1 Reply
Hey,
I ran into a problem just now. When exporting my fusion .brd data to ANSYS all vias with the same size are handled as if they're the same padstack. A couple hundred of them are blind vias (L1 to L2) though and they get interpreted as going from top to bottom as well. Now basically every net is shorted to some other net. Is there a way to to solve this without having to fix a thousand vias manually in ANSYS?
1 REPLY 1
Hi @mweigand82BMM,
I hope you're doing well. I'll contact the developers on this, would you be willing to share the file or a stripped down version for us to analyze? That would help us figure this out.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
