Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Integration between Eagle is not pushing holes into Fusion for PCBs
2 REPLIES 2
sensordynamix
188 Views, 2 Replies
Hello... I have noticed this bug while using Eagle and Fusion. It seems to have just come up in the past week or two. The holes that I place on the PCB in Eagle are not pushing correctly to Fusion. The rest of the through holes from the device footprints are pushing but the holes created for the actual board are not. I use this feature regularly to design enclosure mounting and I'm currently stuck while this bug exists.
Labels (4)
2 REPLIES 2
Hi @sensordynamix ,
For now try breaking the link and then re-linking it.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
I had to relink it to a new design but that solution did work with that small variation. Thank you!
Technology Administrators
