I have a design I'm working on. The 'Insert' menu button is missing from the schematic editor, the 2D pcb editor, and the 3D environment. Because of this, I can't use the Traceparts extension, or even save a part from somewhere and insert it into my design.
It's not a matter of resetting the toolbar layout, as those options are grayed out when I right-click on the toolbar.
What happened to the Insert function? It's present if I'm just working a 3D model of something, and need a screw from McMaster or a connector from Traceparts. Why can I not insert electronic components into my electronic designs? If it's just not there, why isn't it? If there's some 'trick' in using it, there shouldn't be.
If I could find the connector I need in a library, it probably wouldn't matter. But when the library selection is limited to incomplete and/or obsolete parts, or parts without 3D models, inserting from an outside source is necessary.
