Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Insert logo in a frame of schematic
2 REPLIES 2
microlab.l
361 Views, 2 Replies
What is the procedure to put my company logo in a frame of a schematic.
Thanks.
2 REPLIES 2
PlasmaMan
in reply to: microlab.l
Your can do this if you have a .dxf file of the logo. Use the command run import-dxf in the F360 command line. Make sure you select the layer you want the graphic file to import to. You will have to adjust the scale, line width and position so it make take some trial and error.
Good luck!
Hi @microlab.l ,
BTW, you could also create a library which has only symbol with the imported dxf (e.g. I put it in 97. Info layer) and then add the device in schematic file. Hope it helps a little.
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
