I am trying to create a part library for a microcontroller board to use in my designs. The basic part has connectors that will plug into a PCB, so it is used as a module within another design. Doing the basic part is not a problem, the problem is that the microcontroller board has parts on it that are not brought out to the connectors and I would like to have that information present in either (a) the part library itself, or (b) at least in the schematic the part is used in. The ideal scenario would be to copy the parts from the schematic of the microcontroller and paste them into the doc or notes layer of the schematic the part is used in. That doesn't seem possible, they are always inserted as a schematic element, not as a graphic. I also tried copying the schematic part out and pasting it into another app as a graphic element and then trying to copy and paste that in, but the schematic only sees other schematic elements on the clip board, not external graphics elements. Same with the library symbol editor. I can put text into the docs or notes but not a graphic element. As an example the microcontroller module has a micro SD socket on it ( no pins brought out) and I would like to document this in the part library or the schematic the part is used in, other than just a text note.
If this is not possible I would like to suggest it as a feature enhancement.
