Inherit Trace Width
hh68Z3D
Inherit Trace Width
hh68Z3D
Is it possible to inherit the trace width from selected trace when routing? I have a lot of different widths and it annoys me that the fusion does not suggest the same trace width as the selected trace. I have to manually set the width every time I am rerouting a trace.
HelenChen-ElectronicsQA
Hi @hh68Z3D ,
Thank you very much for your suggestion.
I will log a ticket to our development team for review. Thank you.
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
Hi @hh68Z3D ,
Hope all is well.
I just realized that you could press Shift key when starting route from existing wire, which will have the same width as an existing wire.
Shift+Left starts routing with the same width as an existing wire.
Could you please have a try?
Hope it helps.
Helen
Helen Chen
