Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Include/exclude component in/from BOM
10 REPLIES 10
Message 1 of 11
silvio3105
189 Views, 10 Replies
Can user somehow have (same) component but somehow place component without footprint.
In my case I have SH1106 1.3" I2C OLED display. I can solder that display on PCB and in that case I want to have that display in BOM.
In other case I want to mount display on enclosure, so in that case I want to place only display in schematic, but not on PCB and exclude component from PCB BOM.
10 REPLIES 10
Message 2 of 11
silvio3105
in reply to: silvio3105
Bump!
Message 3 of 11
jorge_garcia2
Hi @silvio3105,
I hope you're doing well. This sounds like a good use case for variants. If the component is populated then you solder it to the PCB and it's included on the default BOM ulp. If the component is not populated then it will not be included in the BOM.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 4 of 11
silvio3105
in reply to: jorge_garcia2
I'm not sure do I understand what you mean.
Message 5 of 11
jorge_garcia2
Hi @silvio3105,
I hope you're doing well. Since you could build the board in 2 different ways or "variants" you could use the Assembly Variants feature to create a variation of your board that doesn't have the screen populated. When you generate the bom.ulp you can select what variant to produce the BOM for. If you pick the default('') then the screen will be mounted to the PCB and soldered down. If you pick your other variant then the screen will not be populated on the PCB and the BOM will reflect that.
Let me know if you have any other questions.
Best Regards,
Jorge Garcia
Message 6 of 11
silvio3105
But in that case it will be big X over component in schematic.
Message 7 of 11
CGBenner
@jorge_garcia2 👆
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
Message 8 of 11
silvio3105
in reply to: CGBenner
Maybe he's on vacation?
Message 9 of 11
C.Nicks
In the standard Eagle desktop version you can create a library part with the library attribute _EXTERNAL_ in order to have a schematic symbol and device without a footprint.
That part would have to be a separate version than a footprinted version.
I also use a custom BOM export script that will excluded any component with an BOM->EXCLUDE attribute regardless of the variant populated status.
Things like that might be a bit harder to handle in Fusion since the attributes within libraries are hard to find/modify.
Best Regards,
Cameron
Eagle Library Resources
Message 10 of 11
silvio3105
in reply to: C.Nicks
I know for _EXTERNAL_ but c'mon, it's 2022, why mix old way with new?
Message 11 of 11
silvio3105
Bump!
