Importing netlist or netscript in Schematic Editor
deepak_elango
deepak_elango
I want to import netlist or netscript in my schematic.
Can anyone suggest how to do this ?
Best regards,
Deepak Elango
jorge_garcia
Hi @deepak_elango,
I hope you're doing well. Importing a netlist is possible but it's will require some work. Basically, prior to importing the netlist you have to pre-place all of the components and make sure their reference designators are the same as what is being called out in the netlist.
Are you doing this to try to get data from another tool in? Unfortunately in the ECAD industry import/export is a difficult task because everyone keeps their files formats secret. Commercially, I believe we are the only ones that have an open file format in XML, open source tools keep their file formats public.
If you can give me some insight into what you are trying to achieve I might be able to find a better solution for you.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
deepak_elango
Hi @jorge_garcia
I hope your doing well too.
I want to know what files can be imported in PCB editor?
Kindly reply ASAP.
Best Regards,
Deepak Elango
