Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Importing DXF while maintaining Layers
2 REPLIES 2
osamaolabi
275 Views, 2 Replies
Hello everyone,
I'm new to Fusion360, and was hoping for little guidance on a problem I'm having.
I have a DXF file that has multiple layers for a PCB. for example a hole layer, a copper layer, and just the base layer.
How could I import those to Fusion360 while maintaining those layers in the PCB?
I want to have the holes layers, the copper and the pads all separated.
I was able to import the dxf in the design mode and that would give me multiple sketches for the layers. but I need those to be in the PCB design so when I export it, the manufacture knows which are pads and which are holes and  etc...
Thank you for your help 🙂
Labels (3)
2 REPLIES 2
jorge_garcia2
in reply to: osamaolabi
Hi @osamaolabi ,
I hope you're doing well. Unfortunately, the DXF import will only import the entire DXF as a flat single layer so you are better off separating the layers into individual DXF files and then importing those into Fusion 360.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
osamaolabi
in reply to: jorge_garcia2
Thank you for your help :).
Have a wonderful rest of your day.
