- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I try to import a DXF in Fusion360 Electronics as a "20 Dimension" layer, and then import another DXF as a "1 Top" layer, I get bad results in Fusion.
If i do the same importation in Eagle, the importation works as needed. I then can save it as .brd and link it in Fusion360 with no problems. But having not to use Eagle would be a huge time savor.
I could not figure out why this is happening, any help would be really appreciated.
Attached are the DXF Files, Fusion Files and Eagle Files. I also attached photos of how I import DXF's using Eagle and Fusion.
Thank you so much for your help in advance,
Osama
