Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Import from EAGLE converts cylinder surface to polygons
1 REPLY 1
944W5QY7
144 Views, 1 Reply
I have a RJ45 female connectors in my project (from Adafruit library just in case). First connector works correct.
I try to add another RJ45 connectors same type to scheme. And holes in them adds as set of polygons instead cylinder surface. (screenshot attached)
I tried to remove them individually and all together, then add them again. The situation is repeating itself.
1 REPLY 1
jorge_garcia2
in reply to: 944W5QY7
Hi @944W5QY7,
I hope you're doing well. Depending on the size of the whole sometimes this will happen and it normally doesn't create any issues for modeling.
If it is actually creating a difficulty please let us know and we'll investigate further.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
