Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
import-bmp "Format specifier/argument type mismatch"
2 REPLIES 2
infoBKDH3
222 Views, 2 Replies
I would like to import a bitmap into my PCB design using the ULP script "import-bmp". Everything seems to work fine: opening the bitmap, selecting colours and even when I click "show BitMaP" in the final dialog window it is able to properly show me my bitmap. But then I click "OK", which gives me the following error message:
Error: <html>/Users/<my_username>/Library/Application Support/Autodesk/webdeploy/production/730a059d1ffbbf4403b5320eacd667066bfc243e/Autodesk Fusion 360.app/Contents/Libraries/Applications/Electron/LibEagle/examples/ulps/examples/import-bmp.ulp(820):<br><br>Format error in call to 'printf()':<br><pre>"...s/230203 bitmap patterns/10 dpi 10%.bmp' (0 %.4f);\n"<br> ^</pre>Format specifier/argument type mismatch</html>
How to solve this problem?
Labels (3)
2 REPLIES 2
jorge_garcia2
in reply to: infoBKDH3
Hi @infoBKDH3,
Try renaming the bitmap so that it doesn't have the % sign in it. Special characters in filenames can sometimes create problems and I think that's what's going on here.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
infoBKDH3
in reply to: jorge_garcia2
Yes, thank you!
