Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
I cannot change via diameter size.
1 REPLY 1
sellyette
156 Views, 1 Reply
I want to use 10mil via and 12mil (or 15mil) diameter.
but the diameter is fixed to larger than I sat.
I guess the size is fiexd 31 mil.
how to change this.
1 REPLY 1
jorge_garcia
in reply to: sellyette
Hi @sellyette,
I hope you're doing well. You can't make the diameter any smaller because of the annular ring settings. Check out the documentation for this here:
https://www.autodesk.com/products/fusion-360/blog/what-you-didnt-know-about-eagle-restring/
Let me know if there's anything I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
