Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
I broke the interface by drag/dropping a library file (.lbr)
1 REPLY 1
michael.bolay
84 Views, 1 Reply
Hi, today I managed to broke both the "place components" panel and the library manager windows by simply drag/dropping a .lbr library file into them. Once the library file dropped, the panel / window display the XML content of library file...... It's then impossible to use the panel / window.
The only way to fix the issue is to restart Fusion360.
1 REPLY 1
Hi @michael.bolay ,
I hope this message finds you well. I'd like to ask what were you trying to do? Drag and drop workflows are not supported in those panels, so I'm pretty sure that opening the XML is not what you were trying to do.
On the flip side, the panels shouldn't do ANYTHING when you drag and drop on to them so the fact that they opened the XML is concerning. I'm reporting the issue to the development team. In the mean time let me know what you wanted to do and I'll tell you how.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
