Announcements
How to show name of component after turned off?
larsVMB3B
larsVMB3B
Hi!
Please see attached screenshots.
The name "R36" has been turned off and is invisible. Now I need to turn it on again - how could this be done when the actual label for the name is not shown (nor clickable) for its properties?
Thanks in advance
Replies (7)
ritste20
Did you turn it off or delete the text object on the board editor?
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
larsVMB3B
I just turned it off
ritste20
Try going to change>display>name and select component. Maybe that will get the designator turned back on?
Steve Ritter
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
jorge_garcia
Hi @larsVMB3B,
I hope you're doing well. Use the Autoposition attributes command and set it to restore default then click on the component. This will bring back the name and value texts.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
larsVMB3B
Thanks both Steve and Jorge!
It turned out that Steve's suggestion worked
larsVMB3B
Hi again,
Sorry to open up this thread again, but after the latest software update I just can't find the Autoposition Attributes command. Previously I beleive it was under: Document > Draw > Autoposition Attributes.
But where is it located now?
panpan_fan
Hi @larsVMB3B
I hope you are doing well!
Now the Reposition Attribute command is in the ATTRIBUTES list.
Please check, thanks!
Panpan Fan
