Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to share schematic/layout files with others?
1 REPLY 1
anthonyEX9NB
160 Views, 1 Reply
One of the reasons my company started using Eagle (CAD Soft) was because it was easy to share designs with other designers. Now that we have upgraded to Fusion 360, I have no idea how to share a design with somebody.
Back in the day, one only had to share the .sch and .brd files with somebody and then they could open the file for viewing and to encorporate into their own work.
Given that I am a new-ish Fusion 360 user, the only way I can see to share a design is to print the schematic to a PDF, generate the BOM file as a .csv, and generate the gerber files for somebody else to re-create the entire design.
How are designs supposed to be shared with Fusion 360?
A little more detail ... I am trying to share a design with a student. Student means they are not likely to be in a position to buy a subscription to Fusion 360.
1 REPLY 1
Hi @anthonyEX9NB,
I hope you're doing well. The best option is to invite the student to the hub and then share the project with them.
See this help page
https://help.autodesk.com/view/fusion360/ENU/?guid=GD-SHARE-PROJECT
You can always export the project but the hub allows for more collaboration.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
