How to set up a rule for SMD-to-THT clearance?
lars.jepkens
lars.jepkens
My supplier said that he needs at least 2,5mm clearance between SMD and THT pads, so I've tried to set up such a DRC rule, but the only thing I could find was clearence betweet smd-to-smd and tht-to-tht.
I need to set up that rule for same and different signals.
Please do not tell me that I could run a specific ULP from some sketchy website.
jorge_garcia
Hello @lars.jepkens,
I hope you're doing well. We do not have an smd-tht for different signals but we have one for same signals so that one you can set in the clearance tab.
In that same tab you'll find the pad-pad clearance which use the same value for both smd-smd and tht-tht. If your manufacturer gave you different values for smd-smd and tht-tht then use the stricter of the two for both(the larger of the two).
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
