Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to select technologies of a part in schematic?
1 REPLY 1
tagy22
92 Views, 1 Reply
Hi, I am creating a library of parts. For a resistor I want to have several values available with all the correct attributes for each value. I have been able to do this using the command line in the library.
But how are you meant to see and select which technologies a part in your schematic is using? Only way I can see how do do this is add a part then select replace part and click through to the library -> part -> and then there will be a list of the the technologies I have created. But is there a better way?
1 REPLY 1
tagy22
in reply to: tagy22
So I found how to do this not longer after posting this question. I will heave it here in case anyone has the same issue. (Does not seem to be much about this online). Let me know if you know a better way.
You can choose the technology of a part before dragging it in to you schematic using the 'Select Attribute set' in the 'Place components window:
If you have already added a part, you can use the Modify -> Change (c) -> Technology to select a different technology:
