How to save CAM Processor to custom directory?
_Marek
_Marek
For all my projects I use the same configuration as below:
I would expect that after clicking "process job", all results will be saved in directory:
E:\Elektronics\{Project name}...
There is option "export to project directory", but the destination place is...weird, like this:
C:\Users\mssof\AppData\Local\Autodesk\webdeploy\production\b738a7f16475c27414ba957f7f0b2ee5b34e4e6d\Applications\Electron\LibEagle\examples\cam\examples
I can guarantee that I will never find CAM results without exporting them again. Moreover, drive C this is system partition, which will be cleaned up after every OS reinstallation. Is there any way to customize "root" location for all exports?
yqliu
@_Marek , you can change the CAM directory from application preference:
stephen_rinaldi
Hello
Is there any way to make this project specific and not global?
fk_cad
is it possible to save it so its attached to the project, or even as a file in the data panel. Rather than a isolated file on my C drive
jorge_garcia
Hi @fk_cad ,
I hope you're doing well. It is currently not possible save the CAM output to the Fusion hub. This is something we are working on but it still hasn't borne fruit.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
