Announcements
How to rotate entire board?
jimUR4RG
jimUR4RG
I would like to rotate my entire board 180 degrees but I can't figure out how to do it. I've tried to select everything and then using the rotate tool, but that only rotates single components. I know there a group command but I cannot figure out how to use it. Any help would be much appreciated!
Jim
jorge_garcia
Hi @jimUR4RG ,
I hope you're doing well. Here's a procedure for rotating the entire board.
1. Select everything
2. Left click and drag, you'll start to move the entire board
3. While the board is moving right click to rotate it 90 degrees, right click again for 180
4. Release the left-click to drop the group back down.
This is one of the simplest ways but there are others and some are more precise. You could do this through the command line as well if you needed to rotate about a very specific point.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
jimUR4RG
That did the trick, thanks!
