Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to put PCB design into an array for CNC milling?
2 REPLIES 2
jwilkins8475
429 Views, 2 Replies
New user here. Sorry if this belongs in another category, but it seemed like the best place to start.
I have a PCB design I've created - a small, simple board with a handful of parts and a couple connectors. I want to put this bare PCB into what I've only ever heard called an 'array' or a 'matrix' - a larger, single board that many smaller boards are cut from. But the terms 'array' and 'matrix' seem to mean something else in the F360 world, as my searches yield very little in the way of useful information for this situation.
I've found that if I lay the schematic out X number of times, when I go into the 2D PCB editor, I can arrange everything more or less how I want to, but having to move 6x or 8x worth of parts around is a non-starter. Plus, getting it all to line up with the dimensions of an 8x10" sheet of double-sided copper-clad (what I'm going to mill them from) is pretty tough.
Is this step (arranging to a PCB 'array') done in the Manufacturing environment? The 2D editor? The 3D editor? Should I have started with my 8x10 copper-clad when I initially laid out the dimensions of the board?
2 REPLIES 2
yqliu
in reply to: jwilkins8475
jwilkins8475
in reply to: yqliu
Thanks! I'll have a look at those.
