Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to pour a polygon inside a ground plane
2 REPLIES 2
CaptainMJ
618 Views, 2 Replies
Hi! Need some help, I have a ground plane that fills most of the bottom layer, I now want to add a another plane for VOUT inside the ground polygon. The problem is that when i draw the VOUT polygon on the bottom layer it doesn't seem to create any clearing between the VOUT and GND polygon. What's the correct procedure to do this?
Attaching the result from my attempt.
Marcus
Best Regards,
Marcus
2 REPLIES 2
edwin.robledo
in reply to: CaptainMJ
Hi CaptainMJ,
That is a great question, thanks for posting here.  Go to the properties of the large polygon and set the rank to 6.  Then set the rank of the polygon inside the larger polygon to 1.  Rank 1 polygons will subtract from other polygons.
Ed
Edwin Robledo
Tech Marketing Manager
CaptainMJ
That worked perfectly, many thanks for the help!
Best Regards,
Marcus
