Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to place second symbol of part with two symbols in a schematic?
1 REPLY 1
vovakk
207 Views, 1 Reply
I'm creating a schematic in which I'm trying to use the adafuit quad op amp part. That is an ic with 4 op amps and a power + ground pins. It's split up into two symbols: the op amp symbol and the power/ground symbol.
When I place it, it places the op amp symbol and increments the pins on it accordingly. However I cannot figure out how to place the power/ground pin symbols.
Here's the part with the two symbols:
Here's what happens when I place it: it lets me place op amps cycling through the pins, but never the pwr/gnd pins.
The Add Part menu shows  the power symbol, but I don't see any way there to select it:
1 REPLY 1
vovakk
in reply to: vovakk
The reason the symbol is not showing is because it's add level is set to request, so it is hidden by default.
You can show it by invoking it: right click on the part in the schematic and click invoke, the select the pins.
