Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to make a circular PCB with square cutouts?
1 REPLY 1
208 Views, 1 Reply
I tried the board outline tools, first I make a circle, then a 3-side of a rectangle I want to cut out, but it won't cut out the rectangle. If I close the rectangle with the 4th side, the whole board shifts to that little outline and ignores the circle.
1 REPLY 1
silvio3105
in reply to: 6338179621
Since trim tool does not exist you need to use arcs for that.
- Make PCB layout with circle
- Add cutouts
- Delete circle
- Connect cutouts with arcs
