Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to import KiCAD projects into Fusion 360 or Eagle?
1 REPLY 1
Design-IVB
708 Views, 1 Reply
I'm looking to import our KiCAD Projects into Fusion 360 in order to utilize the electronics side of Fusion and optimize our workflow.
How do I import KiCAD files into Fusion 360 or Eagle? Can someone from Autodesk suggest a method or tool to import the KiCAD projects into Fusion 360 or Eagle?
1 REPLY 1
Hi all,
A BETA version of our new KiCAD importer is now available through the insider program. The insider program gives you access to our next release (May) ahead of time so we can collect valuable feedback. It is compatible with the production version of Fusion.
Instructions on how to sign up for the insider program are here:
https://forums.autodesk.com/t5/fusion-electronics/become-an-autodesk-fusion-insider/td-p/10552765
Instructions on how to use the KiCAD importer will be available in the insider forum (Electronics section) once you sign up.
Pieter-Jan Van de Maele
Senior Engineering Manager, Fusion Electronics
