Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to import CAMoutput files back into Fusion360
1 REPLY 1
garrettsheadrick
105 Views, 1 Reply
I'm trying to make some edits to a board design that was created a year ago. I don't have the original project they were made with anymore, but I have the CAMoutput files still. Am I able to re-import these files into Fusion so I can make a design edit?
1 REPLY 1
Hi @garrettsheadrick,
I hope you're doing well. In most cases importing gerber files into a design tool is not worth the effort. In a certain sense CAM export is a one way function, where the bare minimum is generated to get a board manufactured. You won't have a design netlist, you won't have a schematic, nor can you reverse engineer a schematic from the gerbers because these are just artwork.
If the modification is very minor(like adding a single trace) you can probably do it in a gerber editor. You can try importing the gerbers back into Fusion using the import-gerber.ulp that comes with Fusion 360, however it likely won't give you the info you need to be able to make significant mods.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
