Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to give two pins same name when creating component
1 REPLY 1
jakobtPG23B
433 Views, 1 Reply
Hi
I have two VSS in the component I'm creating, and I've tried naming them both VSS, but fusion 360 won't let me. Is there any work around, or do I have to name them "VSS1" & "VSS2"
1 REPLY 1
jorge_garcia2
in reply to: jakobtPG23B
Hi @jakobtPG23B,
I hope you're doing well. You technically don't need to do this, since you can assign multiple pads to a single pin. So in the device editor you can assign both VSS pads to the single VSS pin.
If for for some reason you still want to do this, you can by appending an @ symbol at the end of the pin name. So it would be VSS@1 and VSS@2. When you look at the symbol on the schematic the @ part gets supressed so it just looks like two VSS pins. This is the old school way of doing it. We recommend the new way.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
