Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to fork a electronic design correct?
3 REPLIES 3
HarrySatt
181 Views, 3 Replies
Hi
what I need to do is to end the electronic design at one point and quote it with finished. After that I would like to add a complete new design but do not want to start from scratch but keep on using the finished design for further enhancements to reach a new finished version and so on. If a design is manufactured it should be halted at that version and a completly new design should be started on the top of this outcome.
At the moment I use milestone for this but in fact it is not what I really want. If I f.e. design a test design and want to use it for starting point of more then one design than I run into this problem. How to disconnect correctly all the links in the design and how to copy to a really fresh location?
@RichardHammerl
@jorge_garcia2
3 REPLIES 3
RichardHammerl
in reply to: HarrySatt
Hi @HarrySatt,
you could mark your finished design as a milestone, that's a good idea.
For continuing with a new project you could then just create a new electronics design, and then link to your existing schematic and board, BUT be sure to check the Create a copy option in the file dialog.
Best regards,
Richard Hammerl
HarrySatt
in reply to: RichardHammerl
Sounds useful. Are there all links set to the new (copied) design so that I can rename the SCH, BRD the folder and generated 3D to other names and assemblies. Or do I have to change the links in assemblies to newly created 3D designs.
Regards, Harald
@RichardHammerl
jorge_garcia2
Hi @HarrySatt ,
When you follow Richard's procedure, you get a completely separate copy so you don't have to worry about poluting the original design you copied from.
Hope this helps.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
