Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to edit global attributes
6 REPLIES 6
sebastienSQA5P
962 Views, 6 Replies
Hi guys, in Eagle I was able to edit global attributes by navigating to edit » global attributes... however I can't find where to edit this in Fusion 360, hoping you could point me to the correct place
(My projects define global variables like >REV, >DATE, >TITLE etc)
6 REPLIES 6
anyone?
rajat.goel
in reply to: sebastienSQA5P
Hi @sebastienSQA5P ,
We apologize for the inconvenience. Unfortunately there is no option yet in Fusion Electronics UI for editing Global Attributes similar to Eagle (in Edit drop-down) but you may perform command ATTRIBUTE * in Fusion Electronics CLI to get the Global Attributes dialog in Fusion and access and edit your global attributes there.
Hope this was helpful. Please let me know if you have any other questions regarding this.
Rajat Goel
Software Engineer
Autodesk Fusion 360 Electronics
sebastienSQA5P
in reply to: rajat.goel
That would explain why I couldn’t find it !
im ok with the CLI workaround, thanks for responding.
Kristey
@rajat.goel
Global attributes are diferente between Schematic and board any way to have the same Global attributes on Schematic and Board?
Hi @Kristey ,
I hope you're doing well. There's currently no built in mechanism to have the same Global attributes on both the schematic and the board. By design they each get their own set.
@HelenChen-ElectronicsQA I think there may already be a ticket for this. Could you confirm? If there isn't it would be a good enhancement request to have a mechanism to sync the global attributes between both.
In the meantime, if you find yourself using the same set of attributes constantly you could write a script and run it on both editors to create the attributes for you.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Hi @Kristey , @jorge_garcia2 ,
Thank you very much for your feedback.
I just logged a ticket to track this requirement. Thanks!
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
