How to display device name on pcb
erussellK6Q8Z
Message 1 of 11
erussellK6Q8Z
I am trying to display the device name on the pcb. After reviewing the library footprint I realized I had forgotten to add ">Name" to the tNames layer for the device. It has now been added and the library updated. Now the text ">Name" shows up on the board, not the device name. I have tried replacing the part in both the schematic and the board with no luck. How can I get the device name to replace the text ">Name"?
Elizabeth
Replies (10)
Message 2 of 11
AlinaPeng
Hi @erussellK6Q8Z
Sorry to hear that you're having trouble.
Could you please check if you set proper layers for the Name and Value in the symbol and footprint editor?
Symbol Name -  Layer should be 95 Names
Symbol Value -  layer should be 96 Values
Footprint Name - layer should be 25 tNames
Footprint Value - layer should be 27 tValues
If all above informations are correct, would you mind share with me your library by exporting the library as flbr file? I can take a look at the library and help to figure out the issue.
Best regards,
Alina Peng
SQA Engineer
Message 3 of 11
panpan_fan
Hi @erussellK6Q8Z
I hope you are doing well!
I want to add another tip besides Alina's comment.
Would you mind checking if you addd extra blank space between '>' and 'Name'?
It should have no blank space between them.
Panpan Fan
Message 4 of 11
erussellK6Q8Z
I was able to get around this is by creating a new footprint and device. I still don't know what the problem was with the original footprint. The layers were all correct. And there was no space between  ">" and "Name". The new footprint and device look identical to me to the old one that doesn't work. I have attached the exported library file. The device that works properly is TEST_POINT_LOOP and the footprint is TH_63MIL. The device that isn't working properly is TEST_POINT_THPAD_LOOP and the footprint is TH_1_6MM. Hopefully you can figure out what went wrong.
Message 5 of 11
panpan_fan
Hi @erussellK6Q8Z
Thanks a lot for your flbr file. I can reproduce this issue now.
I will reported it to our develop team to have a look.
The '>Name' text in your footprint is different. You can see that the '+' icon is far away from the '>Name'.
I am not sure the reason for it. If you can remember something special, please let us know, thanks!
Panpan Fan
Message 6 of 11
panpan_fan
Hi @erussellK6Q8Z
We find the reason for this issue now.
There is empty space after '>Name'. You can delete them and see if it works well for you.
Panpan Fan
Message 7 of 11
RCBakerBorn
I am having the same issue and this does not help. There are no extra spaces.
One thing I do recall, is when I export from Eagle to Fusion 360, the component is fine.
This only happens when creating a footprint or symbol in Fusion 360.
Message 8 of 11
matt.berggren
The quotation marks are not used for the >NAME in either schematic or PCB.  Please remove these and check if this works.  You can also check these things just by creating an Global Attribute in PCB and giving it a name then referring to it using the text string >Your_Attr_Name.  If the syntax is correct the attribute is resolved properly to the NAME or VALUE or both depending on what is displayed.  I’ll try and generate a gif to show this process as a way to test some things more easily.  I use these all the time for title blocks.
matt, autodesk
Message 9 of 11
RCBakerBorn
Matt,
Thank you for your reply and advice.
Your suggestion of omitting the quotes has fixed the issue.
I made the updates to all the footprints and symbols I had in my library and they display the name and values correctly.
Thank you,
Chad
Message 10 of 11
dave3PGN8
I had the same issue and found that I had a newline after >NAME. Eliminating all white space after it solved the issue. Thanks!
Message 11 of 11
kterryTYYYC
FYI, there is a ULP script to do this automatically ...
