Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to define a pad stack with different annular rings on each layer?
2 REPLIES 2
eric_engineer
138 Views, 2 Replies
How can I define a through hole padstack with different annular rings on each level?  For example I want to shrink it or even eliminate it on the inner layers.
Thank you
2 REPLIES 2
@jorge_garcia2 any feedback on this ?
Peter Doering
Hi @eric_engineer,
I hope you're doing well. Go into the Annular Ring settings in the DRC and adjust the inner min and max values to 0 that mill make sure you have no annular rings in the inner layers.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
