Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to Create PCB layout Assembly drawing for manual assembly
2 REPLIES 2
yuvraj_wadye
222 Views, 2 Replies
Hello Fusion,
I Want to create assembly drawing from electronic pcb layout for manual assembly.
I have to give it to the assembly person .
Give solution ASAP.
Thanks.
2 REPLIES 2
Hi @yuvraj_wadye,
I hope you're doing well. Turn on whatever layers you want to include in the assembly drawing and type export followed by the enter key in the CLI. A little menu will pop up, go ahead and select Image.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
But I want a full assembly drawing with Components designator in the middle of the footprint.  I created somehow similar drawing with manual rotation and placing of designator,but I its time consuming .
If there is any shortcut or command to do this then let me know .
I am attaching my work file to give you idea about that .
Check it ...
