Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to compare two different versions of pcb layout
3 REPLIES 3
anuradha.bodke
354 Views, 3 Replies
Hello Team
I have two pcb layout versions in both some modifications are done
so without checking netlist I want to compare difference pcb layout version and get what modifications done
such as package, net
can this possible in Fusion Electronics? if not Please add because it was useful any other software have this facility
Anuradha
3 REPLIES 3
Hi
If I understand well you want to compare 2 PCB Layout ? if yes note that you can open many PCB file in Fusion.
Tell me is this what you need.
Best and have good luck.
Hello, RitchieParis
I mean to say that it is have any command for comparing two  pcb design ,
that can be generate log file having differences of both
this facility have in pads
Anuradha
Ah ok I see, but unfortunately Fusion can't do that, at this time ? Fusion is still in the making.
Very sorry you must to do that manually.
Best and don't hesitate if you need help.
