How to combine multiple designs into one PCB
adrian.beetz
adrian.beetz
Hello guys,
it seems that in Eagle there was a functionality to combine multiple PCB designs into one (https://electronics.stackexchange.com/questions/255223/combining-multiple-eagle-pcbs-to-one)
Unfortunately that is not working with Fusion 360. Is there a feature that allows to combine multiple (already routed) pcb designs to be combined into one. Reason is that I would like to order just one PCB and cut it afterwards.
Thank you for your help
Best Regards
Adrian
C.Nicks
Fusion Electronics does not seem to have the same Import->EAGLE drawing option that would typically be used to do this.
This is one of the main reasons I cannot use the Fusion version. You'll either need to export the files in standard Eagle format and push them together with the desktop version, or process gerbers and use an editor to combine them.
Best Regards,
Cameron
Eagle Library Resources
adrian.beetz
Thank you for your reply. I guess the problem is that with combing the files afterwards with gerbermerge I can't add extra traces for cutting (or changing the outline of the board in a way that only some small parts keep the boards together)
