Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
How to combine bodies in an imported PCB?
1 REPLY 1
ir232
377 Views, 1 Reply
I imported a PCB from Eagle to Fusion360 and want to combine bodies of individual components on the PCB. However since everything was imported, I can't edit it directly. I made a screencast depicting this problem more clearly. Is there a work around to this where I can combine bodies and edit individual components in the imported assembly?
1 REPLY 1
yqliu
in reply to: ir232
Hello @ir232 , it's not recommended workflow to edit a body inside a PCB part directly. Please refer to the other post, e.g. https://forums.autodesk.com/t5/fusion-360-electronics/not-able-to-replace-component-body-in-3d-pcb-w... for more information.
